Give a Flying Duck
Hello, Everyone.
Duck, from Yellowknife here.
So, I have one of these:
Xtra Speed Trail Glider SCX10 CNC Machined Aluminum Fully Upgraded 1/10 Scale Crawler 313mm WB ARTR #XS-CAR-908,
Originally, my friend and I each got one to build together and then I got hurt and had to take a few months off for wrist and hand surgery. Don't worry, I learned my lesson. Gramma always said that'd happen... and I'd get hair on my palms...
Aaaaanyway…
My friend has had *NOTHING* but problems with his front axles. He's tried 3-4 different brands and they all bust.
I need this rig to be ultra reliable, I don't have a lot of time to wrench.
So I've come to the conclusion as neither of us can figure out why the thing is destroying front axles, that when I build mine I have to redo the bottom end -- axles, housings, etc.
I wanted to just put vanquish axle shafts in it, but apparently I can't as they are different... which means I have to go to a SCX 2 axle .. which is the whole rebuild mentioned above.
This sucks. A lot. This truck has sat for 5 months post surgery because I get annoyed every time I look at it.
It's money I don't really want to put into the build that takes away from something else. Especially as I tend to be quality oriented.
So, I'm asking.. because I am sort of desperate here.
I want this machine to be super reliable for fairly high mileage trailing and a TTC in July.
Do I even have any choice but to use Vanquish axles and housings? I'm really not happy spending $700 CDN on a pair of axles... My thought is if I'm going to spend $400 I might as well get portals..
What would you all recommend?
Ideally, I'd like to *FIX* this and keep the cost down but make it 100% solid.
Portals are not necessary, just saying if I have to spend high dollar I will try and get the best I can.
Are there more... reasonable ideas out there... besides me blowing all that coin?
Any ideas for a fix, or a set of less expensive but 'rock solid' options?
Aaaaanyway…
