RC4wd wheels and tires...
Abrown83
Melbourne
Can someone please tell me if RC4wd rims will only work with RC4wd tires or can I use lets say 1.9 ripsaws from a dingo with stamped steel wheels?
Thanks!
The older ones, I don't think they will, but if it is a recently purchased set "newly made" they should. From what I've gathered RC4WD redesigned the inner ring to work better with other brands of tires. I have a set of Pro10s that have the updated ring and a set of OG steelies that has the original design. There is a member/vendor on here that makes a ring that helps eliminate the bead issue with other tires.
i had to press mine with a vise to start the lug screws on my steel wagon wheels, but it worked just fine
I really like the idea of 2.2 spacers. the look is pretty sweet:) Now i do have 1 ? is the rim a 1.55 ?
