RC4WD warn 9.5cti winch help
Brehrocks
Fort Saint John
I have been looking at this winch for quite awhile now and had a few questions about it. You can plug the winch into your reciever and run off your third channel on your controller, i only have a 2 channel controller. There is the winch wireless controller that you can plug into a seperate battery. i have a third channel on my reciever, could i just get the RC4WD winch wire pack? i noticed it has a reciever to reciver wire. I have the cc bec. I also have the hitec 7955 titanium gear servo. Im running onyx 2000mah 35C 2S lipo.
thanks
Get the wireless winch controller. You can run it off a separate battery, or wire it to run off your current battery. I have this setup and run it off a separate 3s 1500 mah battery.
you can get a dual plug connector or an inline adapter...or just peel back a little insulation and solder it to the esc battery lead..
