Finished this build a few days ago, #5 of my Toyota Lexan Crawler list. This may be an older body when it debuted to the RC world but it was a must-have to add to the fleet. As you all know it's a pretty narrow body, but I did my best with a set of 1.55's and a slightly shorter tire than a 4.19. With how I have the arches trimmed and body sitting, the only rubbing is the front of the front arches but it's not that bad. Very doable and most importantly I can keep the look.
This build isn't 100% finished though as you don't see the front bumper installed and hope I'm not forgetting to mention anything. I've got the newly released Team Garage Hack single bar bumper kit (sample pic below) on the way for the front. I think it will be the perfect solution for this front end. Kept the small lip there with the upper mounting holes for the stock bumper still just in case I want to hack that bumper and be able to install it. Also debating on overdrive, but need more run time on it. So far it's an amazing crawler despite the rear overhang on departure. I'll include a running video when I get the chance.
Parts list:
- Amazon: CF rails/front bumper mount (servo relocation)/CF cross member (battery/electronics tray)/rear aluminum cross member
- 3S Micro X/1100kv Team Brood Riot SS outrunner 9T pinion/JX 35kg servo
- Austar 3 gear transmission
- Stock skid
- InTheWorks RC titanium high clearance links (SCX10II to 10.3 AR45 straight axles)
- SSD aluminum C hubs
- Traxxas 2660 big bore shocks/Mini T spring combo (50wt F/R, need to try 40wt)
- RC4WD 1.55 steelies/Pitbull Braven Berserker (3.95)
- Front "fool" stage foams
- Cheap shimmed steel driveshafts (will upgrade to Incisions)
- Rock Pirates RC front shock towers (splitting body mount diameter in half allowed reuse of SCX10 holes I previously made when I had the stock towers on)
- Rear universal shock towers
- Team Brood B-Mag 78mm Magnesium posts/braces
Parts list:
- Stock skid
