So I just got some steel beadlocks and rc4wd IROK tires. To replace my stock cut canyons. Foams are toast on canyons. Like running 3psi in a 1:1. But, I've noticed the IROK seem to have less grip? I like the looks, but know the center tread pattern is more close together than the cut canyons. I have no brass yet. Is there anything to help the IROK be a little softer? I'm non vented too. I run wet and dry and don't want to swap tires or have to pull foams if I don't have to. Will venting make that much difference on them?
