RC4WD Blazer Cab Backs for Pickuo Conversions.
RexRacer19
Let me 3D Print that...
Concord
This is a detailed cab back that can be used in converting the RC4WD Chevy Blazer into a pickup. It features window trim detail (along with a ledge to help mounting the window easier), stamping details, and a precise fit that should allow for easy finishing. The cab back should be a big time saver that will produce nice results for those who want to convert the Blazer to a pickup.
There are two versions of the cab back. The first is just the cab back by itself. This is for people that are building a custom interior and do not intend to use the stock RC4WD interior parts.
It can be found in the Mod19RC Shapeways store here: https://www.shapeways.com/product/9PE4KXL4L/rc4wd-blazer-cab-back?optionId=65074035&li=marketplace
The second version includes an adapter so that you can use the stock RC4WD interior parts. The adapter has to be attached to the cab back with two M3x8mm Flat Head Socket Screws. The screws are visible on the cab back, but the heads are recessed in a way that lets you easily fill over them prior to priming and painting. Here is how the adapter attaches to the stock interior using the Blazer body kit screws.
And here is how it looks in the body.
This version can be found in the Mod19RC Shapeways store here: https://www.shapeways.com/product/9...rior-adapter?optionId=65092702&li=marketplace
Thank you for your interest in the cab back. I hope that is a help to builders everywhere.
