Lobonyc
Story: A while back i got two DS cars in trade for a new in boxed tamiya f201 ferrari. One was restored into a Lamborghini DS RC10Talk.com - View topic - RC10DS Lamborghini Gallardo.
The "RC10DS White Parts Special" was born from the second DS. First off, the chassis was scratched and then painted over with a black sharpe so a new one was needed. i acquired a full set of Dyno-Tech racing white nylon arms and thought of mating them to an anodized emerald green DS chassis i have been saving. Here is a photo link of that chassis
https://www.instagram.com/p/_ALOjsouTQ/
Then i thought i could use the carbon DS chassis i have...Here is a photo link
https://www.instagram.com/p/_AMEuQouUr/
Sandkil from rc10talk suggested a black and white themed DS carbon chassis build so it was begun.
The Dyno-Tech racing arms
i decided to take remove the black powder coating off the nose plate and engine mount with some EasyOff oven cleaner and sandpaper.
I swapped out the original stock DS black parts for white parts.
I replaced all brass bushings with bearings
Replaced the stock black ball ends with RPM white ones
The hubs and suspension arm mounts were placed on a carbon DS chassis (not by associated)
The Dyno-Tech Racing arms are installed along with a set of GPM blue anodized front suspension arm mounts
Problem enountered with the white arms...they are missing the hole for the shock mount tabs indicated by green arrow
Problem solved by removing the anti roll bar and reassigning the hole to fulfill shock mount tab duties. This in turn created a new problem. I lost ride height as the shock position is now lower than the stock.
problem solved by using the RPM long shank ball cup ends
White parts battery tray, antenna mount and a fiberglass battery brace
White part rear bulkhead and stainless steel hardware
Axle cups polished,blue anodized GPM dogbone used, White parts Axle hub and white a rpm ball end cups
White parts used on the team shocks as well
The Rear
The front
Angle Photos
Body choice has not been made yet but more updates to come.
The Rear
The front
Angle Photos
