donaldsneffe
Wow - how cool is this!
RadioMaster MT12 Surface Radio Controller 2.4GHz ELRS/4-in-1 Multi-protocol
Radiomaster Website
RadioMaster MT12
Physical dimensions: 177.8*118.4*207.8mm
Weight: 480 grams
Operating frequency: 2.400GHz-2.480GHz
Internal RF Options: 4-in-1 multi-protocol / ELRS 2.4GHz
Supported protocols: Module dependent
RF power: CC2500 and 4-in-1: 20dBm max. / ELRS: 24dBm max.
Operational current: 160 mA for 4 in 1. 400 mA for ELRS 250mw .
Operational voltage: 6.6-8.4 VDC
Control distance: > 1 km @ 20dBm
Operating system: EdgeTX
Control channels: Maximum 16 (Rx dependent)
Display: 128*64 Monochrome LCD
Battery: 2 x 18650 or 21700 battery
Charging: Built in USB-C Charging
Firmware Upgrade method: Via USB or SD card
Gimbal: Hall-effect Module bay: Nano size (Compatible with TBS Nano Crossfire / Nano Tracer / RadioMaster Nano-size modules)
Features:
* Available with built-in ExpressLRS or 4in1 MPM RF modules
* Featuring a powerful STM32F407VGT6 with 1MB Flash
* Preinstalled EdgeTX firmware
* QC3.0 fast charging supporting 2.0A MAX
* Compact design with excellent ergonomics
* Oversized battery compartment - 2 x 18650 cells or a 2s 7.4v 5000mah battery pack (Batteries not included)
* Standard Nano module compartment
* RadioMaster standardized button layout
* Rotatable antenna
* Customizable base switches or 4 way joystick included *32 channels requires a 4in1 radio and additional 4in1 RF module along with compatible receivers
R85C Receiver Specification:
Item: R85C Receiver
Power supply: DC 4.5 -8.4V
Frequency range: 2400-2483.5Mhz
Support protocol: D8/D16/SFHSS
Output channel: 5CH PWM
Antenna type: High-sensitivity 2.4G antenna
Telemetry power: 100mW/20dBm
Weight: 5.70g
Dimensions: 31.00*18.50*13.00mm
ER3C-i Receiver Specification:
Item: ER3C-i 2.4GHZ ELRS PWM Receiver
Power supply: DC 4.5-8.4V
Antenna type: Built-in high-sensitivity ceramic antenna
Wireless protocol: ExpressLRS 3.3.0 pre-installed
Output channel: 3CH PWM
Telemetry power: 10mW
Battery voltage detection range: DC 4.0-35V
Weight: 4.2g
Dimensions: 26.1*18.5*13.0mm
Firmware: Device Category: Radiomaster 2.4Ghz/ Device: RadioMaster ER3C-i
EdgeTX Operating System Preinstalled with EdgeTX, the MT12 has cutting edge software fit for its class-leading hardware. RadioMaster works closely with the EdgeTX team to develop new features and optimize the user experience for surface models. We will continue to contribute and support projects like EdgeTX, ensuring the concepts of open standards are carried forward.
Tons of videos released 2 hrs ago, find some here:
https://www.rockcrawler.de/thread/5...ter-mt12-16-kanal/?postID=1792486#post1792486
More pics:
https://www.rockcrawler.de/thread/5...sender-radiomaster-mt12-16-kanal/#post1792486
Radiomaster Website
RadioMaster MT12
Weight: 480 grams
Features:
* Rotatable antenna
Item: R85C Receiver
Weight: 5.70g
Weight: 4.2g
More pics:
