Questions about mod1, mod.8, 32p etc
crisco
Colorado
EDIT. Adding this to the beginning to clarify I guess. Read the rest if you want to understand what I am trying to do.
I just found this and it makes sense.
http://www.rctech.net/forum/electric-off-road/516626-how-understand-gearing-ref-pg1.html
So I guess the easy question is what mod 1 spur gears work with the scx10 trans with a slipper eliminator?
If not, what 32 pitch (mod .8) gears work with it?
The only thing I found was some duratrax gear from a nitro truck. Back when I was racing Robinson Racing sold spur gears with several hole patterns in them to work with different cars but I can't seem to find anything like that.
The whole thing is going to be more of a basher than a crawler so I need a smaller spur than a crawler.
END EDIT:
I have a few questions.
I am back into the hobby after a long hiatus and need some gearing advice.
I did lots of research but since I am making a frankenstein I can't seem to nail down what I need.
I have an SCX10 transmission with a slipper eliminator. Not sure of the brand, but it has a plastic hub the slipper bolts to. That hub has 3 locating pins that go into the spur, which is held on with three bolts.
I am using a Mamba 2650 with a 5mm shaft.
The trans has a 48 pitch spur (something i am familiar with from back in the day) but I need beefier gears.
SOOO, since I pulled the motor out of a Mad Force I bought used, it has MOD 1 gears, which if I understand is NOT 32 pitch.
I can find mod1 pinion gears with a 5mm bore but I can't seem to find any spur gears that would work with this trans and the slipper eliminator.
What do I need to be looking for?
I would like to stay with mod 1 so I can put the MMM back into the Mad Force if I want and not have to buy new pinions.
But in the end it seems to be coming down to the spur gear choices for the SCX10 trans. That's my focus right now.
Any ideas?
I do have a few traxxas trucks with an assortment of their spurs and read somewhere you can use a traxxas slipper on the axial trans but I don't see how that would work. But I also don't have the axial slipper to reference.
I bought the trans used so I don't have the slipper parts if that makes a difference. I did buy new steel gears and an aluminum case for it though.
If this post is too long for a typical forum post let me know. I will revise any others I do.
I don't know what typical forum etiquette is.
Thanks!
Agreed, you are putting way too much thought into this. Just grab pinions and rock it as 32 pitch. Use 54 or 56 spur and give her hell
Kimbrough has all the multi hole spurs you could ever need.
Agreed on 32p, pinions are like $6.
I'd go with 32p too. All my 32p have a 5mm bore, I just use the RRP pinion reducer sleeve.
This is what's in my BMRC IFRS wraith.
Supershafty bomb proof transmission.
Locked up RC slipper eliminator.
Robinson racing wraith/ax10 blackened steel spur gear part #1558
