*Public Giveaway - 5mm Extended & Lightened AX/SCX Trans Outputs -Crawler Innovations
Nova's Ark
Tire&Foam Extraordinaire
Subscribed Member
C.I. Compound, Tyler, Texas
The giveaway winner will be chosen by a random number generator on September 1, 2017.
This giveaway is open to any member of the RCCrawler forum.
However, Crawler Innovations highly recommends supporting the original website that birthed the RC Crawler hobby into what we have today. If you would like to support RCC, the information about becoming a star holding member is here: click this link.
Post once a day to be entered.
Crawler Innovations is giving away one set of our 4340 steel, Lightened & Extended front & standard length rear transmission outputs for Axial transmissions. This is a permanent fix to weak outputs.
This design incorporates a 5mm round with cross pin hole.
These outputs work with any manufacturers drive shafts that are 5mm.
These outputs are cut from 4340 "Chrome Moly" steel.
They have been lightened by gun drilling the back side of the output, down the center. The 3 piece tab arrangement also reduces weight. These are the lightest and strongest SCX outputs available.
The reason the front shaft is longer is to move the drive shaft away from the spur gear. This added clearance allows for the use of larger spur gears in order to gear lower for increased torque & smoother start up. For brushless motors it is critical to ensure a smooth start up with no cogging.
They are sold in a set which is one long front and one short rear for $54.95
CWR-5013
They can purchased @:
RC Crawler Foams, Rock Crawler Foams, Tires and More by Crawler Innovations
Here is a set installed on my SCX-10 based 1.9 scale Toyota. I am using a 96 tooth spur gear and 15 tooth pinion on a Tekin 13.5 sensored brushless inrunner motor using a Mamba Max Pro on 4S. The truck is as smooth on start up as my brushed 2.2 comp trucks using Holmes Hobbies hand wound motors.
Yes, it's a giant 96T spur gear but the smooth crawlability even with a brushless motor is amazing.
Here you can see just how much clearance you have between the output shaft, spur gear and drive shaft yoke. You could actually go bigger if you can find a company that makes a bigger 48pitch spur gear.
This pictures shows that the drive shafts clear all link mounting and links.
Re: *Public Giveaway - 5mm Extended & Lightened AX/SCX Trans Outputs -Crawler Innovat
Awesome! I have a set of your killer foams, please accept my entry...
Would love a set!
Sent from my SM-G900V using Tapatalk
Wow, will they work on the wraith Eddie ?
Hang up and Drive
Thanks for the chance! You make great foams so these should also be great! "thumbsup"
In, thanks "thumbsup"
in for a set. these are sweet!
I like that design! thanks for the opportunity..
Enter me! Thanks
Could definitely use a set of these. Count me in. Thanks!
In on this. Would love a set for my 6x6 project.
I'm in, and that is some seriously cool shit.
Sign me up
