Portal Axles?
Wraith1985
Gosport
I got these axles in a small lot buy and I'm not sure what they came from. Does anyone know what the portal adapters are from? I need replacement gears.
Sent from my SM-G986U1 using Tapatalk
i might be stoned but I could sware it says integy on the portal housing
the axle housings look like SSD d60 housings for the scx10
but I could just be high
maybe take a cover off and get a pic of the actual gears and input shafts most likely integy will be able to help you but since they like to copy sherbet they might use a off the shelf gear set from axial or traxxxass
Ya they say Integy, but they make alot more of them than I thought. Ya that's an approach I could take, my experience in the past from them wasn't that good so I thought I would try here. Maybe I'll try and reach out to them and I'll take a pic of the gears inside. Thank you for your help!
:shock:
I had the same problem, I looked at them and totally forgot why I was staring at them. :shock:
