Oh yah, I understand how complex it is. It may be possible to adapt some of the solid axle kits to the front of the TH. The steering knuckles aren't that different from their solid counter parts. Mad moose makes a kit that looks like it may be close.Yes the trx4 axle is very impressive but again this is solid and not independent , this is the Hum vee front end and as you can see is seriously complex , can you imagine trying to miniaturise this and produce it so it's relatively a universal component available to most platform and within a price range which is affordable to most hobbyist ??? This is why it's not available , also the amount of ball joints that would be needed which is literally unheard of in 1:10 scale
Thanks for the insight.Technically it wouldn't take anything more then making a new set of C hubs for the independant suspension that took the TRX or MSX portal housing. The axle is already connected by a CV joint.
It would take no more ball joints then a normal 4wd rc car would take.
Just because it has not been done does not mean it could not be done, it just means companies like staying in the safe area of tried and true and accepted technology.
If you want portals on your Twin Hammers you are going to need to do a bit of work, decide what brand portal you want to start with, then make an adapter C hub to fit that in place of the stock knuckle. Someone good at can should easily be able to draft up a portal adapter for the Twin hammers.
The axle will be the fun (hard) part, you will need to find one that will fit in the CV port of the portal and the dogbone end of the twin hammer... I can see some brazing or welding in your future.
I'm not saying it's out of the question
it's just a very detailed and complex design to achieve and obviously cad design and tooling is seriously not cheap , if YOU can do the designs then great that gets the price down ,
I haven't said it can't be done it's just not financially practical and also the question was is there a portal axle available off the shelf , were know moving into the discussion of diy portals and of course this is much in the hands of how competent the hobbyist/ machinist is ,
And yes as clm mentions it does become a bit of a waste if the diff is already out of the way , all that said it does look cool and would achieve even more ground clearance !
Excuse my ignorance but why would the motor direction need to be reversed only for the trx4
