ExoSphere64
Being new to the hobby I expected occasional issue to find me but this one really has me bewildered. I am sorry in advance as this is going to be a little long winded but I need to supply as much info as I can in hopes of finding an answer.
Let me start from the beginning. Early this summer I bought a TRX-4 Defender. It was very reliable and has brought be much joy. I have done extensive modifications but they all have been purely cosmetic.
Enter last month. Out on a demanding trail run and a couple of hours in I experience total steering failure. Based on everything I have read, the stock steering servo blows chunks. Easy fix. New, upgraded servo. (Side note: Only after ordering the new servo, I discovered that the stock servo was just fine, the brass drive gear just stripped out the plastic horn. ordered an aluminum horn)
I ordered the Traxxas 2255 high torque 400. Plug and play. All good for a couple of weeks. Then tragedy finds me once more. 15 minutes into a session, the ESC bakes off and ends my day. Visa card rescues me with a factory stock replacement. Everything back in working order. ( I also picked up a fancy BEC but did not install it)
Fast forward to a couple of weeks ago. Out on a great trail ride. Could not have been more perfect. About 3 hours in, I start having steering issues. Sluggish left and right, very slow and stuttering a lot. I was really bent thinking that my brand new steering servo was already failing. On further inspection, I noticed my transmission and diff lock servos were stuttering as well. (forward/brake/reverse inputs were working fine). I assumed it may be weak batteries in the transmitter so I swapped in a set of new ones. The transmitter never turned back on. It had completely failed. I swapped batteries several times and it was just dead. Visa carded a new one.
All was well in Defender land. I had a beer or 7 and decided to buzz the neighborhood tonight. 20 or so minutes were trouble free. Then all steering faded again. Because of the last experience, I checked the other servos and they were all doing the twitch dance as well. (Transmitter still communicating this time).
I shut everything down and started this post. The one thing that has been nagging me is maybe the steering servo is at the root of these issues. Also being so green I noticed (tonight) that the steering servo I installed was brushless (in a stock brushed) setting.
If anyone has actually read this far (miracle) does anyone have any advice?? Again, being so new, I miss some things. Tonight, while gathering information I noticed that the new steering servo was brushless. Could that be to smoking gun?
I am hoping one you you rock stars can help me figure this out!
