Original SCX Transmission vs SCX10 II Transmission
I know we have seen photos of the two transmissions side by side, but I dont recall seeing any pictures with them sitting next to one another while mounted on the skid.
Using the old style transmission moves the motor weight forward a noticeable amount. The II setup is much longer and even though the transfer case does have some weight to it, overall the weight is more biased towards the motor end.
Here you can see the difference between the motor (and output shaft) height. Using the old trans drops the motor weight down a good bit, but some of that is probably counteracted by the transfer case being so low on the new trans.
Installing the old transmission was easy. Aside from removing the stock trans and skid and installing the OG stuff in its place, it just required finding new lengths for the driveshafts (longer front, shorter rear) and putting a nut on the front upper link since there is no mount on this skid.
I had other plans for this motor but it may end up staying here.
