...well not exactly.
Like a good number of people apparently, I was amazed to see Vanquish launch a new kit for a far more reasonable $499 - and will admit it's the first time ever I've clicked 'buy-it-now' on the day of release...
I was doubly pleased since I already had a project in mind which I wanted to build around a VS4-10 chassis and VFD transmission - however, not having the budget for some pukka Vanquish aluminium axles, was going to have to make do with some Axle SCX10 III axles, which I just wasn't really inspired by - so when the Phoenix kit was announced, complete with some really nice looking Currie portals, it seems this was the obvious way to go!
However, while I really like the concept of the truck-cab FJ40 'Cruiser body that comes in the kit (I especially like the front end, with the modern Vanquish twist on the traditional grille, similar to what they did with their Scout style body on the previous version/s), and feel the bed cage with removable fender panels is inspired - personally I find the quarter panels behind the doors of the cabin gawky with those little (and I do mean little) extra windows in there... Indeed I'm hoping that at some point we'll see an internal cabin cage from Knight Customs, so you can chop the roof off the stock body and make an open top version in future?
Perhaps more importantly, I already had a body-shell I wanted to use on some sort of 313mm chassis project - one of those Injora JK Wrangler hard-bodies (in this instance the two-door pick-up version)... and after a quick eyeball, it appeared that once the rear portion was removed behind the truck-cab roof, it ought to be the perfect length to replace the lexan kit body... and as it turns out it really seems as if this whole chassis (including the moulded front inner fenders) was designed to accept this particular body as an alternative...
Right, enough waffle, a few photos to show you what I mean:
For those of you who frequent the SBG forum, I've already put together a full detailed build-thread there showing how I modified the original 4-door body tub into a truck-cab (using the rear corners to fill in the gap below the roof section, along with some styrene and a lot of glue and filler) - and essentially the result is a 2-door body which not only fits over the inner front fenders as if they were designed for each other (including space for the headlight buckets), but that the front body mount lines up perfectly [if you flip it] with the inner radiator panel from the body set, while the cage bed is the perfect length to mate with the styrene rear panel I fabricated at the rear of the cab - therefore this alternative body mounts in exactly the same way to the chassis as the kit body does (other than because of the thickness of the Jeep grille panel you lose the ability to flip it up from the front, rather you do need to pull the pivot pin each time).
Due to having a general aversion to lexan body panels in general, rather than utilise the kit bed sides (which I'd admit would make this look very much like a Brute style Jeep pick-up of course), I elected to leave them off for the time being - although they can always be attached using the kit clamps of course - and fabricated my own cage infill panels from aluminium, together with diamond-plate deck between the bulkhead and the rear suspension towers.
I also already had a set of genuine [now discontinued] Vanquish Method Roost aluminium wheels and VXT tyres which immediately found a home, together with a fifth tyre on a very similar Ebay spare wheel.
Inside job
Because of the layout of the electronics and shift-servo on this iteration of the VS4-10 chassis, it was going to prove difficult to incorporate a full depth interior - particularly as the Overdrive shift-servo is on the driver's side of a LHD vehicle... However, with a little more custom styrene work and the assistance of Dr. Dremel, I feel I've managed to hide the battery and also incorporate the key parts of the original Injora Jeep moulded interior - including the top of the cubby/cup-holders, the seat backs and cushion fronts - cut down and attached the battery cover, while the driver figure 'Dustin' was modified to fit around the necessary step in the seat-box... unfortunately he did have to lose his lower right leg.
Fortunately there is enough room in the cabin to retain his full left leg (which helps to hide the servo and shift mechanism when viewed from this side), while the ESC power switch is easily accessed under the front of his seat:
While I have endeavoured to incorporate a number of scale details into this build, it is foremost a trail runner - designed to be used (as the scuffs on the top of the roof already reveal), and together with the versatile selectable transmission and DIG options, I have also incorporated a servo-winch and switchable LED lights - utilising all 6-channels of my GT5 remote in this application.
Test run last weekend, prior to driver installation and a few refinements:
If you have any questions I'd be more than happy to share more info. about what I've done with this build, and trust you appreciate this twist on what is clearly already a very popular kit!
Jenny
Inside job
Jenny
