jaloos
Been out of the electric RC hobby for years till my son and I bought a pair of Exceed Max Stone 10's. I did a fair amount of work to one and actually managed to get a good working little crawler.
After surfing the forum for a while I decided to build an AX-10 based machine totally from scratch. I was debating an rtr AX-10 kit but figured I would be replacing alot of the stock parts eventually anyway.
I have a decent Towerpro MG995 high torque servo ( will run it till it craps out then replace) and a FlySky GT3B with an extra reciever that I bought to use on my HPI Nitro Bullet that will fit the bill pretty good for the crawler.
There are several other parts that will need to be swapped out for the drive line but I figure this will give me a good working roller to improve on.
Below is a list of the parts I ordered to assemble the rig.
Big question here is how badly did I mess up with the parts combinations?
Any input would be greatly apreciated.
Axial SCX10 AX10 Transmission Set (plan to assemble in the mirrored configuration.)
2 X Scorpion AX10 Rock Crawler Locked Axle Set AX30488
Axial Heavy Duty Diff Locker AX30500 For AX10
Hot Racing's Axial AX10 Scorpion SCX10 aluminum rollcage chassis SCP14RR01
Hot Racing's Axial AX10 Scorpion SCX10 aluminum center skid plate SCP13301
2 X Hot Racing's Axial AX10 Scorpion SCX10 aluminum suspension link mount SCP55M01
2 X Hot Racing's Axial AX10 Scorpion SCX10 120mm aluminum reservoir shocks TD120RR01
Hot Racing's Aluminum Universal Center Drive Shaft SCP37H05, AX10
2 X ST Racing Concepts AX10 Scorpion, Aluminum 4 Link Front or Rear Plate
Axial Hardware Upgrade Kit AXA1411 AX10 Scorpion
Axial Aluminum 6061 Servo Horn 25T AX30836, AX10, Wraith
AXIAL AX10 Scorpion, Aluminum Rear Steering Links Red
Axial RTR Steering Upgrade Kit, AX10 and SCX10 AX30426
Aluminum Pivot Balls Green (20) SCP160B05, Axial AX10
Axial AX10 Scorpion Threaded Aluminum Pipe 6 x 101-A30 by 3Racing AX10-13/GR (bent lower links)
Axial AX10 Set Screw M3x16mm Black Oxide AXA186
2 X Axial Post 7x 70mm: Gray (2pc): SCX10 AXIA1431(upper links)
4 Losi Comp Crawler 2.2 Beadlock Wheels & Tires Rock Claw Night LCC LNC (got a good deal, pulled from a kit never used)
Tekin Racing R1 Brushed/Brushless ESC (got a good deal installed but never used, figured it would give me the option to go brushless without further costs)
10 pair T Plug Connectors Deans Style Male and Female Connectors
14 Gauge Silicone Wire 10 feet
Axial AX10 Stainless Steel Screw Set 200+ Pcs RCZAXI001
