ebeowulf17
Hey everybody, two questions about NiMH packs that seem like they should be really basic, but I can't seem to find answers.
First, how do you know when it's time to recharge? Without really knowing how much battery I needed, I ended up with a 5000mAh 7.2V battery for my SCX10II. It seems to last forever. I've measured voltage after several runs and it doesn't change much. I've read that you don't want to recharge NiMH if it's too close to full, because chargers are looking for a characteristic voltage drop near full charge, and if the voltage isn't low enough when you start, they never see the pattern, at which point they run way too long, overheating and over charging the battery. On the other hand, I don't want to just run it until it quits - I'd like to charge up frequently enough to know I can finish a hike with it before leaving the house.
So, can I measure voltage and get anything meaningful from that? Or do I just have to get spare batteries and run one all the way down before switching?
The other question is about heat during charging. When I first got the battery, I charged it right away, and it was pretty hot at the end of the cycle! I've run it quite a bit for the last week or so, and finally the voltage had dropped enough (reading 7.3V, down from a peak of around 8.05-8.10) that I decided to charge it. Again it came out very hot. This time I measured, and it was 150F! That's hotter than I expected. Most articles I've read say that there's not too much heat when charging properly, although I found one article that said 130-140F at the end is ok.
What do you all think is acceptable heat from a pack at the end of charging?
Almost forgot to mention, I'm using a brand new Spektrum S150, charging at 5A rate. I've read that charging up to 1C is good for NiMH and that charging too slow can actually cause problems where the charger doesn't recognize the end of the cycle. I originally bought a Tenergy TB6B, but it was DOA, and weeks later they still haven't sent me a replacement. I'm pretty peeved right now. Anyway, got the cheaper, simpler S150 just so I could finally start playing!
