Photoninja
hi guys i have a servo on order
JX PDI 5521MG 20KG High Torque Metal Gear Digital Servo
it has the following spec...
Brand:JX
ItemDI 5521MG Servo
Dead band: 2μsl
Working frequence: 1520μs / 330hz
Operating Voltage: DC4.8~6.0 V
Operating Speed (4.8V): 0.18sec/60 degrees
Operating Speed (6V): 0.16 sec/60 degrees
Stall Torque (4.8V): 17.25kg.cm (239.55oz/in)
Stall Torque (6.0V): 20.32 kg.cm (281.89 oz/in)
Dimensions: 40.5X20.2X44.2mm /1.59 X0.80X1.74 in
Weight: 55.6 g (1.96oz)
Connector Wire Length: JR 265 mm (10.43in)
does anyone know from the details if it sounds any good, or even have one and most of all will it work for a steering servo on the dingo builders kit.
The first ever crawler i have ever owned which i think is gonna cost me an arm and a leg by the time ive done replacing the plastic should i say less durable parts and upgrades i am aiming for brusless setup eventually you should see what i did to a tamiya df02 chassis lol that will give you an idea i have the url on my profile for those interested thanks in advance for any sensible answers please
Edit So the servo arrived...
and this is how the tamiya df_02 ended up..
Brand:JX
ItemDI 5521MG Servo
Dead band: 2μsl
