NEW: Wet/Dry Sandpaper Packs
Locked Up
SCALE PERFORMANCE PARTS
Vendor
Cedar Park
If you are looking to sand/buff/polish pretty much anything, these variety 5 packs are just what you need:
Wet/Dry Hobby Sandpaper - 5 Packs
Each 5 pack contains 5 different grits in an easy to use 4.5"x3.5" size.
We use these as part of our "Polished to Hell" process and they are perfect for refreshing beat up bead lock rings!
  • These sheets are made of silicon carbide for sharp cutting and long service life.
  • These are electro coated so they will not fall apart like store bought pieces.
  • Resin bonded sandpaper ensures the backing flexible and can conform to odd shapes.
  • Waterproof sandpaper sheets can be used with water, varnish, shellac, lacquer, or oil.
Coarse. 80-100-120-150-240 Grit
Medium. 320-400-600-800-1000 Grit
Fine. 1200-1500-2000-2500-3000 Grit
Thanks for reading!
