TRX-4-Baker
Howdy RC- Crawlerpeople!
Fellow American abroad with new TRX-4 Sport and... since last week proud owner of a TRX-6. My trucks are primarily used on trails and walks with 1-2 hours total runtime. Offroading basically limited to whatever is encountered or looks manageable. Speeds are "normal" walking pace, between 6-8 miles total per day.
Both trucks are electronically stock, upgrades planned for later are HW 1080 + Holmes, however likely a fall/ winter project. Weight is of significance due to trying not to limit range.
Not being sure about the battery story, I went with normal 3000 MAh NIMH from Traxxas and I am seeing 1.4 - 1.5 hours from the Sport and about 1.1-1.2 hours from the TRX-6. Thats about half of what I would like to see. I use the EZ Peak ID charger from TRX.
Questions: Could you guys share which battery would bump my endurance to roughly 3-4 hours? I know there is a perfect setup for every situation. TRX Support tells me to go 2S 7400 MAh Lipo (2869X) others tell me to completely dump TRX- ID, which I would rather not do at this time. Buying both trucks was approved by the "finance department" spending hundreds more on hopups and stuff will cause consternation...
While the sport with its single speed transmission seems very balanced (slow enough, yet fast enough for intended use) the TRX-6 seems as if its in wrong gear all the time. In second gear, cruise control on, it shows its lack if flexibility.
IOW: First gear not enough speed, in second gear the trucks motor isn't running at optimal torgue. Not at all a LiPO expert, means the more special terms and abbreviations are used in your response, the more confusion happens.
I have watched every single video from Mr. Holmes on such topics as he has a style of explaining which manages to work well with my level of understanding. Quite unsure. Should one just go and buy the biggest MAh Lipo with the lowest 25C discharge rate? Could the TRX-6 motor struggle less in second gear with a better battery?
Thankful for any and all tips or pointers.
Greetings,
Jason
Greetings,
Jason
