As far as parts compatibility the ECX Barrage, RGT Adventurer, V1, and FTX Outback 1.0 are all identical.
The HobbyPlus CR-24 also sold under other brand names is very similar, Even parts that are not identical are very similar and may be swapped with little to no modification.
The CR-24 has different electronics with a nicer transmitter from Turbo Racing, the transmission with more gear reduction, axle housings that look more like a street truck, functional bead lock wheels, different tires (tires and wheels will swap) a more previously standard shorter 030 motor instead of the longer 050. The links look identical but they are slightly different lengths and the upper links mount in a slightly different position, the chassis rails are also very similar, But with different style shock mounts and a few holes in different spots.
Axle internals and of course gear ratios are identical, the housings and knuckles and carrier are different, but can be swapped around.
The FTX Outback 2.0 is just a rebranded HobbyPlus CR-24
The RGT Adventurer V2 is similar to all these other trucks mentioned, but the 050 motor is moved to the front And there's a transfer case where the transmission used to be. The extra room in the center allows for a lower floor so you can more easily use a full interior, and moving the motor up front gives a slightly better forward balance for getting up over obstacles, It also comes with a transmitter similar to the Hobby plus Turbo Racing transmitter but with analog dials instead of digital buttons, this transmission setup has much more gear reduction than the Barrage/FTX, but still less than the HobbyPlus CR-24/CR-18 and unlike the HobbyPlus transmission there's no easy way to add a larger spur gear for even more gear reduction.
The FTX 3.0 is just a rebranded RGT V2
For what it's worth there's also a CR-18 which is a slightly wider and longer version of the CR-24 with upgraded parts. The axle centers are the same, but widened with wider carrier hubs and rear lock outs, longer links and drive shafts made with a better fiber reinforced plastic, And the drive shaft universals are also now metal.
There's other improvements to it over the CR-24
There's also an FTX Outback 1/18 which is just a HobbyPlus CR-18
Now there's also a RocHobby 1/18 Katana which is basically a CR-18 with a really nicely detailed hard body, 050 motor, new tires and wheels, and the electronics and battery moved up front underneath a working hood
There also a FMS/RocHobby Atlas 6x6 power wagon based on the HobbyPlus CR-18 parts
Sent from my Pixel 3 XL using Tapatalk
