Thanks! That makes alot of sensehttps://www.amainhobbies.com/ssd-rc...front-axle-universal-shafts-ssd00313/p1152372
Everything else from a normal multi piece AR44 axle should be compatible (you’ll need a ssd center section) if I’m not mistaken.
I know people are going to buy these to add weight down low, but I don't see them adding much weight at all.
Can you tell us the weight of this aluminum tube set versus the plastic?
I can see using them to add weight...but, they'd also make the axles stronger, don't ya think? Metal tubes into plastic pumpkin should be stronger than plastic tubes into plastic pumpkin. I haven't checked (yet), but, if there's a metal pumpkin, that would be even better, yes?I know people are going to buy these to add weight down low, but I don't see them adding much weight at all.
That's what I was thinkingI'd get em just to run an offset pumpkin myself
If I understand correctly, you can get the offset tubes in plastic or Aluminum correct? The aluminum is not the same as the "heavy metal" used in the standard Pro44... Correct? If so, why? I would prefer the metal version to be heavy.
Was already thinking the same thing. I'm considering the VS4-10 chassis, and some petal axles...but gotta figure out how to set it for a 329mm wheelbase.Anyone stick these under a VS410 Chassis Kit? I might do that.
That's my plan. I recently ordered the SSD Offset front axle and another VFD Transmission. I just need to figure out if I am going to use it on a current VS4-10 chassis build, or do a new one.
As pic show driverside drop. Can you run these on otherside for a passgerside drop for like a yota front axle?
thanks
It's almost sounding to me like Vanquish PURPOSELY designed the VFD skid to ONLY use the VS4-10 front axle, thus "forcing" buyers of the VS4-10 chassis & VFD trans inner purchasing their $300 front axle. This reminds me of Traxxas, and their proprietary battery/ESC connectors.The VFD needs the upper link mount to be on the opposite side of the offset to work while the SSD offset axles are made to run the upper link on the offset side. It would require a custom axle upper link mount to make the 2 work.
~ More peace, love, laughter & kindness would make the world a MUCH better place
