rbronco21
I finally got everything together and running around the yard, but I have an issue with the motor stopping. Sometimes it will cut out for half a second, then jump forward like the throttle's been blipped. Other times it stops responding completely and doesn't work until I unplug the battery and start over. My wiring is a mess since I'm testing, but let me know if there could be cross talk or interference caused by the mess.
Here are my electronics:
Spektrum SR515
Holmes BR-XL
Holmes Crawlmaster 16t
11t pinion
Power HD LW-20MG eBay Servo
Savox SH-0265MG Micro Servo
1 NiMH battery, 2 2S lipos, 1 3S lipo (same results with all batteries)
I got a couple pics of the ESC light during full throttle and when the motor stops, but I don't see any documentation to tell me what this dim light means.
Full throttle and working, bright green light:
No response from motor, lit during all transmitter input, forward and reverse, dim green light:
I've been in contact with Holmes Hobbies and tried their suggestions and they are helping, I just wanted to get some other ideas to try over the holiday weekend. I don't expect them to be all over my issue, but I know you guys will, and to be honest, I can't even say the issue is with their product or something else entirely.
-The motor came in forward rotation and timed to 6deg. I rotated the endbell 180deg and timed to the correct 6deg for reverse rotation.
-I checked for a hung brush. The spring was slightly snagged in the shunt, but the 2 seemed to move together without issue. I did separate the two without any change.
-There's no heat in the motor or ESC at any time I've checked.
Spektrum SR515
Holmes BR-XL
11t pinion
