So I took the yeti out for the first time and the suspension is pretty bad. What are a good set of shocks and added stability. I’ve see things added other then the shocks for a better ride?
Totally depends on how and where you want to drive it...
This is what I am running now:
Axial stock RTR shock bodies all around.
Axial AX30222 Spring 14x70mm 3.55 lbs/in - Blue in the front.
Axial AX30214 Spring 14x90mm 1.71 lbs/in - White in the rear.
Oil wt 20 in the front shocks.
Oil wt 10 in the rear shocks.
In my experience, this setup works very well on trails. Bumpy ones. At least, I like the Yeti "floating" forward while the wheels wobble away those bumps and holes.
The stiffer the springs and thicker the respective oil, the bouncier a car becomes. And with every vertical movement, the forward speed is reduced. Common thing.
With this setup, mainly the wheels go up and down, so that the car maintains a large portion of it's forward speed. And it just looks better and that's what we do it for as well.
Only downside of a soft setup is that the shocks bottom out easier, especially touching down after jumps. But with the Yeti this is about the same moment as when the chassis hits the ground. So not that bad.
Just try it and find out. Anyway no 4.95 lbs/in and 80 wt or double shock setup for me.
And for the rest, I replaced the rear trailing arms with aluminium ones. The stock ones tend to bend.
Yvo
