After seeing my brother run his Venture which was an Ebay SBK special of sorts before the SBK existed I was very impressed then the actual SBK showed up and that pushed me over the edge. I might have got the same Ebay special but the price had gone up in the mean time.
He's running the Proline Ambush body which gives great approach and departure angles, which is what I also want (not the body)
I feel like I might have got one of the first SBK kits from the sound of things which is not the important part, actually receiving it was as it seemed like it had a very small window of opportunity before HPI went belly up again.
I started off ordering the Scout ii body for it and I just couldn't bring myself to use it even though I've always wanted one. Well a Redcat followed me home and it now has a clear body to paint up and use at some point.
I considered getting the Proline Samurai (Sumo) knock off body and trying to cut off the rear to make a truggy-ish body. I also strongly considered a Carisma Coyote body as my dad had a Toyota Stout for a short while nicknamed the booger as is was geen and ugly, lol
I finally decided on a Proline Dodge Power Wagon which I was hesitant to pick since I know people who have them but I realized that was no good reason to avoid using it.
Anyway I'll get to the pics
Mocking up the body
I cut out the bumped out portion on the front side of the bed that places the cab 8-10mm forward of the bed. The idea was just to push the front axle forward (or push the cab back) which with the front fender shape is totally fitting. It has a long arc to it and where you locate the front axle doesn't really matter much because it looks good almost anywhere forward of center.
I had to cut the bed up to make room for the shock towers. I thought I could 3D print some new shock towers to place them in the recess of the bed but there was really no room to go inwards and forward without creating binding issues with the chassis rail and springs rubbing. Outbording the shocks is not an easy option since they bolt on them front to back for some reason. so cut I did.
I Made some new 3D printed rear shock towers to move the body posts inwards so that they were farther from the edge of the holes cut in the bed, more strength at the body in theory.
The plan for the body changed a bit when I ran it and found how high the gearing was which was limited by the motor mount. It only allows you to adjust down so far, maybe a 14-15T pinion with a 540 or 550. I got down to a 13T with a 400 series HH motor. Anyway with it already being a touch fast I still wanted to go lower with pinion.
In the mean time I put in a Xtra Speed 3:1 GRU/planetary gearbox to try and it was amazing for slowing it down. It was crawling slower than anything I've run, it had superb finesse when in precarious spots.
It was amazing I say because I've already gone back on that decision but I am speaking to you from the future so I'm going to jump around a little. With the motor pushed 25mm farther forward the front biased balance became too extreme. When I simply picked it up from the skid the front would stay firmly planted on the ground while I lifted the rear end. It was quite a shift in balance. This also showed up driving, going down hill was very poor with the rear end wanting to overtake the front.
Back to the future when I'm still planning to use the 3:1 GRU, that left me needing to push the cab forward to clear the motor and GRU. In order to do that I printed a cab spacer. Cutting off that portion of the bed might have been a good mistake because the spacer seems to have made the bed to cab connection really solid though I didn't try it bolted up before cutting it up to compare it to but truck beds are often floppy. This also meant I didn't need to redesign the front shock towers to move them inwards as they would have been a bad spot in relation to the hood.
I decided to use a different location for the battery so I replaced the mount which also served as a crossmember and where the shock towers fasten
Back to the motor mount and gearing limitations I decided the GRU was no good for balance and that a redesigned motor mount to allow for a lower gearing would be the ticket.
A few moments later
Download and print your own here
https://www.thingiverse.com/thing:3569491
more info on the install here http://www.rccrawler.com/forum/hpi-venture/607988-venture-max-gear-down-motor-mount.html
This allowed me to get down to a 10T pinion which is a fair bit better. I also played with a good number of motors to explore different speed motors. I tried a HH 45T 3 slot, 20T HH 5 slot, 16T HH 400 series 5 slot. I did experience what many others have explained that a faster 5 slot motor geared low will have a smoother start up than a high turn (slower) motor. So I ended up going with the 20T 5 slot HH Crawlmaster which they rate between 1000-1500 KV, I though I'd end up going with the 45T but I really like the smoother start up.
I made a few version of the battery tray which started off with the sliders mounts incoprarated into it and ended up being mounted to the sliders that I made.
This battery tray fits along side the BowHouse skid that I'm using and my specific battery, a Protec LIHV 3S shorty
I made up these sliders, they seem massive. (pre weathered)
I used some diamond plate on the top, painted it and scuffed it up
You can see I'm running a Holmes BR mini but I plan to swap in a Mamba X micro to get the adjustable drag brake and the drag brake ramp adjustment to help out while going downhill. For those not familiar it allows you up to 3 different drag brake settings (the Aux feature) and the drag brake ramp gives some options for how gently the drag brake engages. Its really a great set of features, I know many praise the 1080 but I have no interest in anything else after trying running numerous X's
I'll wrap this up later
Mocking up the body
A few moments later
