My "i didn't name it yet" Wraith... Any ideas?
noname0383
Montreal, Qc
It all start with a well built wraith i bought from another member here"thumbsup" thx to him... So i continu upgrading it and build it to my liking...
Specs:
- Axial Wraith kit
- Vanquish locker for Wraith x 2
- Vanquish Wraith Stage 1 Kit
- Vanquish Wraith Diff cover
- Vanquish 3/16" Titanium 10 Link Set
- Vanquish truss front/rear
- Vanquish shock mount front/rear
- Axial Universal
- Axial Wraith Open Hood Kit
- Axial Racing Aluminum Servo Horn 24T Hitec
- Axial light kit w/ controller
- Front electronics box for the Axial Wraith
- Rear electronics box for the Axial Wraith
- Rear cover for the Axial Wraith
- Robinson Racing Hardened Steel Idler Gear Wraith
- Robinson Racing Axial Wraith One Piece Hardened Steel Outdrive/Diff
Locker Gear
- MIP ---Axial Wraith Spline Center CVD Kit
- ****'s 32 Pitch Spur Upgrade Kit
- Fast Eddy Bearings all around (sealed)
- Castle Creation Mamba Max pro
- Tekin pro 4 3300 KV
- Hitec 7954SH (333oz @6v, 403oz @7.4v)
- Castle BEC
- 2.2 Irok X2 SS compound vented
- CI Deuce Wild Single Stage Closed Cell for 2.2 Tall Tires (waterproof), front cut, rear stock
- RC4WD Bullseye 2.2 alu beadlock (+wheel weight)
- Miss Harley Quinn
- Rogue Grfx body Grafic Wrap - Outlaw Skull Red
- Freqeskinz wraith interior - custom skulls
- Integy Aluminum Front Bumper Guard Bull Bar Red
- Warrior rock sliders (would like to "upgrade" with the exo cage/slider/stinger from Mad Skinz:twisted:)
- Alu Gmade servo mount
- Tx/Rx: 4pl
Will probably cut down the rear top, bend it and try to make it hold i don't know how... (saw this on another wraith here on the forum!)...
Have to fix my lovely driver too and lengthen the steering pole to fit her...
Not sure what to do about the shocks tho... Keep the stock one, changed them for? and which lenght? What oil? :roll:
I am a ProLine Power Stroke big bore fan. Go with the front ones for the traxxas stampede
Ok... As a rock racer, it as to keep the low stance tho... Will probably keep the stock shocks for now (matter of budget!) and upgrade later... What oil should I put in those? Don't need to be smooth for crawling, I won't crawl much with it... Need to be performent at med/high speed, handle bump and little jump...
Finally did my rear cage mod... Yes I will buy another Da cover to replace this one and relocate a bit my esc so the cover will fit perfectly...
Should I leave the top complete or cut it in half and leave the rear cage open?
iPad won't let me post more then 1 pics at a time so...:roll:
Re: My Nemesis Wraith
Last one... The top really seems to pull the cover up but in reality it's because of the esc underneath...
Oh yeah, and for the name, a friend of mine came with a couple of ideas...:
- tombstone
- chimaera
- mortifera
- raven
I Like pretty much raven and tombstone... What u think? Any suggestion...?
So, after receiving all my stock and installing it, this is how it looks right now...
-Mad skinz exo-cage w/stinger
-custom lights bracket
-Feqskinz interior
-re-installed the new Da cover
-inner fender front/rear
I didn't had the time to try it yet but my build is quite completed... maybe add some other things... Will see...
