Welcome everybody, Im going to do a ground up build of a Toyzuki V2. I'm going to post this build in sections that will be reserved, so that I can keep all of the pertinent information at the top of the thread. I will try to be very thorough. Pleas post any and all questions and let me know if I make any mistakes.
This first section will include all of the materials and a few pictures of the parts that I purchased for this build. I will also try to post weight changes from previous build to this unit. I have a test bed setup out back that everyone tries on. So far my truck has outperformed all rigs on it. It checks side hilling and vertical climbing. I also have a course that I know how my base truck performed on. I will be able to compare it easily on a performance basis.
My base truck is this SCX10ii kit. This truck was a venerable performer before this massive change, so we will see if all the hoopla is true. It has the following options installed:
Airtronics M4TS radio system
HH Trailmaster BLE Pro
HH Puller Pro 2200kv
HH SHV500 servo
SSD stainless full link kit
SSD rod ends (not much better than axial)
Stock Shocks
LURC high clearance pan hard bar
Xtraspeed ar44 axle housings
HR brass knuckles
Beef patties SLW style
SSD D-hole steel wheels
Pro line Hyrax tires w/ Proline dual stage foams
Toyzuki V2 build list:
Toyzuki V2 chassis
Axial AXA31134
Vanquish transmission input shaft
Adjustable panhard mount
Axial nukizer body
Custom one off front bumper from FB
Rear bumper?
King headz body post mounts
Tekin FXR
Team Brood 35t apocalypse hhk motor
SSD OX winch
12' Mad something RC dyneema rope.
RC4WD roller fairlead
HeyOK winch controller HV variable speed relay
Traxxas 5525 rod ends
Custom stainless lower links
Axial stock aluminum upper links
Axial AR44 axles
DLUX knuckles-8mm, carbon top, brass bottom, slugged
DLUX FBA scx10 universals cut down
SSD hardened gears
Locked Up FI spools
Locked Up OT rear shafts
SSD D hole steel wheels
Proline Hyrax tires
Proline 2 stage foams
Stock shocks
Parts Images:
HH SHV500 servo
Stock Shocks
HR brass knuckles
Toyzuki V2 chassis
Axial AXA31134
Axial nukizer body
Rear bumper?
Tekin FXR
SSD OX winch
Axial AR44 axles
SSD hardened gears
Locked Up FI spools
Proline Hyrax tires
Stock shocks
Parts Images:
