ovstebo
Hello Yall!
Im reading up on motor setups, but cant seem to find a good answer:
What would be the preferred setup,
1. A high turn motor (eg 50T), no or little gearing.
2. A low turn motor (eg 5.5T), with an ultra low gear, GRU fitted (eg 50:1).
Dont know if any of you have tried alternative #2, as all posts Ive read have featured a high turn motor. In most of my cars, going real slow smoothly is a real problem as they have some sort of "minimum speed". This ruins most of the scale appearance as the speed appears "digital". So Im thinking about fitting a real fast racing motor and a GRU, and would like to know if it has been done (here) before, and what the results were?...
Im thinking on using a CC-01 as a base for this experiment, but I suppose the results will be of a more general nature, thus apply to other "slow" scalers.
What Ive currently ordered are:
1 CC-01
1 Ezrun 5.5T motor with ESC
1 5Ah Li-Po, 2S
My general idea is to fit the motor without GRU first, and measure the speed. The required GRU will then be calculated as a function of its top speed and my desired top speed.
Also, if it doesnt work, Ill use the motor in one of my fast cars"thumbsup"
1 CC-01
1 5Ah Li-Po, 2S
