Bart bender
In the pocess of re-designing the 'ol spool design. The main reason for this is that not all people have the means to re-lengthen CV shafts. This will allow you to just cut the shaft to length and lock it down with set screws.
I am modding an original design Yotachump spool. It has a 5mm ID for the stock outputs. I think if these were built from scratch they will come with a 4mm hole. Because so many CVs have different shaft diameters, this will allow the buyer to drill to the size they need for the shaft they have. I have drilled these to 1/4" to except a piece of 1/4" brake line.
I drilled two holes and tapped them to 5mm to accept set screws.
Viola
Viola
