PGT-RC
Hey all, i was wondering if anyone here with a set of Mini T springs could take an inside diameter measurement of one of them for me?
I have two pairs of Tamiya Aeration damper rear shocks (From a DB01) that i want to use on my Bender SWX build, and i was wondering if i would have to modify the bases of these shocks or whether they would slip around the bases.
The shaft itself is the same thickness as the Traxxas shocks, and i currently run Traxxas rod ends on them.
Also, can anyone here tell me if the threading on a pair of stock plastic shock caps is the same as the threading on the aluminium ones? If so then the Alloy ones should screw straight on, as the Traxxas plastic caps seem to fit my TRFs.
~Beany.
~Beany.
