micro racer
What happens when you don't think your 6x6 build is crazy enough, but don't have the shelf space for another 29 inch long truck?
Well, you build an 8x8 Oshkosh HEMTT out of 1/16 Revo parts! Yeah, I do realize this still isn't going to be a particularly small truck, even using the mini parts, but I'm just gonna ignore that.
(490mm from the extents of the front and rear diff housings. Chassis will be longer)
Instead of breaking out the JB weld, Dremel, and a pile of stock bulkheads, I decided to go about this the new-fashioned way. That is: use CAD and 3D print a chassis. I've started by drawing up a set of differential housings, then I'll draw a skeletonized support structure between them, with a pair of 1/2" aluminum channel rails to finish off the chassis. Considering the infamous lack of durability of mini Revo diffs, I'm using a larger inner bearing on the pinion, and increasing the width between the diff bearings to allow for extra shimming. Also, since Traxxas hinge pins generally suck, I'm designing the mounts around Axial's AX31497 2x20mm pins from the Yeti Jr. They're still not amazing, but they're of a more useful length (20mm vs 14mm) so I can support them better.
While I slowly chip away at the chassis design (and to provide necessary dimensions), I picked up four differential gear sets (actually six, because the pinion isn't sold separate from the ring gear), all the seals and internals, two sets of rear A-arms, and all four pairs of knuckles. I actually plan to run mini Summit driveshafts on the front four wheels because I will be using 4 wheel steering, since the Summit's CVDs should work better that the plastic universals of the Revo.
I got tired drawing so I threw together all the diffs and both sets of rear arms.
Unless I start breaking a bunch of arms, I don't think RPM arms will be necessary for this truck. At the hubs, I specifically chose the stock parts so I could use the upgraded Traxxas aluminum pillow-ball cups.
That's all I have for now! Hopefully my Amain shipment will show up tomorrow- *checks clock: 2AM*- ahh, shows up later today.
