MentalGuru
I figured I would start a thread to chronical my modded up TRX-4 Sport kit build for others to follow. As you will see my addiction is real...
Here is a list of the parts I have or are in route at this moment.
TRX-4 Sport kit
BowHouse RC TRX-4 High Clearance Skid
Samix Traxxas TRX-4 Aluminum Front Shock Plate (Grey)
Samix Traxxas TRX-4 Aluminum Rear Shock Plate (Grey)
ST Racing Concepts Aluminum Front Bumper Mount (Gun Metal)
SSD RC 8 Hole 1.9” Steel Beadlock Wheels (Black)
Holmes Hobbies TrailMaster Sport 550 Brushed Motor (21T)
Hobbywing QuicRun WP1080 Brushed Crawling ESC
Traxxas 8196 TRX-4 Two Speed Conversion Kit
Traxxas TRA8249 Slipper Eliminator Plate
Traxxas Over and Under Gear Sets
GRC High Clearance Small C's/Inner Portal Cover's w/Ackerman Upgrade Kit
Brass Portal Drive Housing/Counterweight Balance Weight's 104g
Yeah Racing Aluminum Servo Mount
Savox SA-1230SG Steering Servo
Hot Racing Aluminum Servo Horn
Castle Creations 10amp BEC
Holmes RX Bypass Adapter
Traxxas 8072 Inner Fenders
SMC 1500mAh 3s mini battery's
Scorpion Battery Lock Strap Set
And probably more that I've forgotten from my late night compulsion driven spending sprees.
I'm thinking the body will be painted a Purple/Green Iridescent color.
I'll be flipping the front bumper mounts and using the flipped stock front bumper mount in the rear. The sliders will also be raised about 15mm.
More to come... "thumbsup"
TRX-4 Sport kit
