Whats_a_dickfer
Having an issue with the steering endpoints on my trx4m being maxed out but still not getting enough throw. I've been running these parts for a while, but never noticed the issue until installing a set of meus isokinetic axles. They have 52 degrees of steering, but I can't get there. The specs on the servo say it's got 180 degrees of rotation.
Dual rate on the transmitter is at 100%. I've gone through the procedure to calibrate the tx a bunch of times, hasn't helped. Tried calibrating it but intentionally not turning the wheel all the way to the stops, and then I have less steering, so I know it's taking the calibration.
Tried going into settings mode on the radio, and turning the ch1 Dual rate up and down, and then back up to 100 before saving the calibration. didn't help.
Tried re-binding the tx/rx, didn't help.
Its not a mechanical issue. With the truck off, I can turn the wheels by hand to their maximum steering angle. I'm using the linkage and servo arm specifically for these axles.
I haven't tried using a different radio or servo yet.
Any ideas???
Any ideas???
