MrAwesome987
I have a Mamba X and a Tekin ROC412HD 2300kv setup in my GS02F. I noticed that it chatters a lot when starting off, and started checking wiring. I found that the connector on the motor end for the sensor cable had a broken wire, so I ordered a new Castle direct sensor cable and installed that on Saturday. The truck still chatters along terribly at low speeds. I checked all the settings on the Mamba X using the PC software, and everything looks good. I then enabled the "Sensor lost alarm" and the Mamba X just consistently beeps with 3 short beeps, indicating that the sensor is not detected. Is there a way I can diagnose whether this is a motor failure or ESC failure? I have a few other sensored motors, but I really don't want to tear down another truck just to test with if I can help it.
Thanks.
Thanks.
