cmbscx10
I did some serious searching but couldn't find the answer so reaching out for help. Now that is only after 1 cup of Starbucks so..............
I run Castle MMP, Mamba Monster v1,v2, the Blue Traxxas Monster and program them a plenty with the Castle link Quick connect so i don't have to constantly open the RX box up.
I picked up a Used TRX4 with a Mamba X that has my very first Aux wire ESC. Reading those pesky instructions leads me to my question(s).
On Pg 16 it has a warning "If your ESC has a 3-wire AUX connection (White/Red/Brown) you MUST disconnect it prior to connecting your ESC to the Castle Link USB adapter unless using a Castle Quick Connect Duo. Failure to disconnect a 3-wire AUX connection from the receiver may result in damage to the Castle Link USB adapter." The Mamba X has the White Wire for the Aux so that's kinda understandable (See below) but i cannot see any other Castle ESC that has a 3-wire AUX connection (White/Red/Brown). I of course don't want to blow up this ESC so what are they referring to? The current set up does not have the Quick Connect Duo so i will be getting that on the next order.
My current set up has the ESC into CHh2 on the Traxxas RX using the Orange/Red/Brown but the White Aux wire is not hooked up. I'll need to read more on the Traxxas RX to find out which channel i use for the Aux signal as there is only the second CH1, RPM & VT channels left.
Questions:
What does Castle mean by the 3-wire AUX connection (White/Red/Brown)?
Where do i hook up the Castle Aux Wire into the Traxxas ESC?
Thanks for any Noob Aux wire ESC help
Questions:
