Mac10
After a couple months of ignoring my urge to buy the new pro kit,
I finally gave in!
I've been eyeballing these for a while now.
My problem is I never driver current mini unless it's at a comp.
I never practice, but I always have a blast driving it when I do.
I had decided I wanted a sprung setup so I decided this was a prime opportunity for me to pick up a pro kit.
I love what Losi has done to this rig in the pro kit.
I'm very excited to get it on the rocks (once the foot of snow melts)
I pulled it out of the box and decided really quickly it needed some changes.
I've had a few people tell me how side to side slop is good for performance, but I highly disagree with this statement.
It only causes unpredictability in my opinion!
So far I've outboarded the upper links and moved them to the holes I think will work best(I'm sure I'll be tweaking from my baseline)
Outboarded all four shocks a little more than the outboard kit from Losi gives
You.
I added bent lowers in the rear only so far.
Lunsford steering links
Mip cvd driveshafts
Tekin b1r
Hitec 7950hv servo (hardwired)
Poulson 35t motor
Spektrum micro rx
Thunder power 850mah 45c 2 cell
Od front pinion
Losi soft springs in the front
Stock in rear
30 wt in all four
Limited 1/4" externally in the rear
3/16" internally in front
Losi aluminum beadlocks
Hb rovers
Crawler innovations soft foams in front
Medium foams in rear(trimmed down)
I was able to get almost all of the slop out if the rig and so far it feels really good on the bench.
I'm sitting at 2.3" of gc right now
I'm itching to get it on the rocks and test it.
I think I may need to go to 20 wt oil in the front?
Onto the pics
Electronics plates are .040 styrene.
You'll see that I took a dremel to the leading edge of the chassis to clear my battery.
I finally gave in!
You.
Mip cvd driveshafts
Tekin b1r
Poulson 35t motor
Spektrum micro rx
Od front pinion
Stock in rear
30 wt in all four
Hb rovers
Onto the pics
