The Bug
I currently have an old school Clod Buster based MOA crawler. My problem is when pulling up to an object at low throttle one motor seems not to pull as hard as the other. My set up is a Novak Super Rooster esc with two Integy 55 turn motors. At first I thought it was the rear motor giving the trouble, but the front will also do it when backing up a object.
Is this an esc problem? Should I consider using a esc rated for dual motors? Is it a wiring issue? Or is this just the way it is?
Thanks for any help.
