All you LNC owners please chime in and let me know how well your low voltage cutoff works.
My low voltage cutoff never stops my LNC from running. In fact, I'm pretty sure it does just about nothing. I'll turn off my LNC when I start noticing a lack of power which at such slow speeds is tough to do. When I put my LiPo on the charger it's then down to 5.75-ish volts and the cells are somewhat unbalanced. My charger (Passport Ultra) will test the battery for 2 minutes, all the while bringing up the voltage a bit. It will fail at least once before it gets the battery above the 6v minimum and starts charging normally.
Anyway, how exactly is the low voltage cutoff supposed to behave?
Thanks
Thanks
