Losi Night Crawler dig unit?
Spikex41
Fort St. John
Hey I got a Losi Night Crawler a few weeks ago and I’m just wondering if there’s a dig unit that will bolt up into it. If there isn’t I’m just gonna put rear steering on it but it would be nice to get both the dig and rear steer installed, I’m ordering the Supershafty brass steering knuckles, chubs, and lockouts for it. I’ve upgraded the servo and put hyrax tires with aluminum rims on it and upgraded it to brushless already just looking to start on either the dig unit or the rear steer setup next just having a hard time finding out if there’s a dig unit to drop in.
If anyone knows where to get one plz provide the name of who makes it or even a link to it, thanks a ton.
You'll have to find one used from a comp crawler. Also the drive shafts will need to be replaced if still using the dog bones.
the whole comp crawler trans will drop right on the losi night crawler skid. same skids, and chassis plates.
you will also probably need the losi comp crawler upper shock mounts, spacers for mounts, and chassis braces. the stock lnc battery plate may not fit back in the chassis once the comp trans is installed.
Keep an eye out on eBay. A used dig will come up here and there. We have a LNC with rear steer and a comp crawler with dig. Unless you have a transmitter/receiver set up that will allow you to control the rear separately I would not recommend getting the rear steer kit.
Ya you’ll need the CC battery tray, electronics tray, trany, servo for dig , shock mount extenders and drive shafts . Of course you’ll also need the rx and tx with 3 chanels. There’s a few bits and pieces I’m probably forgetting but that’s about the gist of it.
