Davey
Any advice is much appreciated.
I'm on my third motor with the LNC. Rooster Crawler ESC and a 45t Novak Expert Series crawling motor. 21 tooth pinion. Stock everything else when it comes to gearing. When I get it stuck...even barely stuck in rock crevices and the motor quickly goes from cool to the touch to almost too hot to touch...or it just smokes itself. To be fair, i didn't have this issue with the stock motor or setup, only the aftermarket motors. The second motor i had in it was a handwound 35t crawling motor with the same 21t pinion. I do NOT have a BEC connected...LHS said it wasn't a necessity??? I'm running a 2S 2100 maH LiPo.
I have not re greased the axles once since owning the rig. After reading quite a few posts relating to the LNC and LCC, I'm def going to get this done ASAP for starters. LHS is saying just don't get it stuck in rock crevices....OK to an extent I can do that, but I think its performance is sub par. Any suggestions? Should i be considering dig? An new motor ESC combo? Perhaps a Timbuk2? Simply a gearing issue?
Mark
Mark
