Gents,
I have a used Losi Night Crawler 2.0. It loses power after about 5-10 minutes of operation. I have tried two different batteries with the same results.
Venom 5000 NIMH 9.65 starting voltage/ 9.22 after the power loss. I have a 3000 NIMH that has similar characteristics after 5-10 minutes of operating time. 7.84 start 7.65 after 5-10 minutes.
Temps taken after it loses power. Motor=149 degrees F / Rear diff = 125 degrees F /Front diff =78 degrees F / Battery = 85 degrees F / ESC 75 degrees F. The ambient temp was about 45 degrees F.
After it loses power , I immediately installed the other battery. Same results after 5-10 minutes of normal operation. The drive axles seem to turn easily by hand. I did install a new brushless motor before this test with no improvement. Same problems I had with old motor.
My total rookie thoughts:
ESC or/and worm gear friction. The rear diff, although hot seemed to turn ok.
Your comments are much appreciated
