All I bought was the servo drop and 110mm desert lizard shocks. There are a couple main limit issues with getting more travel if you already have longer shocks. Just be aware that the front is the main issue.
1. Drive shaft angle limit(free)
2. Steering servo link limit. (Around 9 bucks)
3. Shocks (around 50 bucks for Desert Lizard 110)
The first I tackled was the front upper link. All I did was unscrew the upper link until I saw the first thread. In my profesional opinion this wont affect the strength, I machine for a living. This fixes the drivshaft angle limit.
There is a caveat to doing this. Your servo could be stressed more if not done right. You want that limit there if you have a weak servo. Traxxas L.T. kit won't help you here at all. The upper link on the LT KIT is 5mm longer but the bottom links are also longer, that will help limit your shaft limit thus help your servo. (DL shocks can limit too)
The next was the servo link limit. I first planned on heating the plastic baljoints to bend them more. Until I saw the price of a servo drop. This completely fixes the servo link limit, to an extent. *In the pictures you can see that even with the servo drop at full tilt, passenger full decompression, the servo link limits it slightly.
As far as the shocks go. The very first thing I purchased were 110mm desert lizard shocks. These shocks are NOT 110mm at full extension, they're 120. The awesome feature to these is that they come with internal springs that you can tailor to have stiffer decompression. I did put the stiffest small springs for decompression in the fronts. The compression springs have done the best with the lightest springs in all 4.* I will be swapping the rear decomp springs for the stiff ones.
Rear is easy just add longer shocks. Tune as needed.
Thats what I did to get a TON more travel with the trx4 on a budget. You don't need to buy the 180 dollar kit from traxxas, its overpriced. These reviewers can't say that cause they get money/gifts for their reviews.
If you can add a servo horn that has an inside hole. This will give you more leverage, and less stress on the servo.
I'll post pictures as soon as i can but I'm tired, I gotta go to bed. If I have any edits to this ill do my best to label them. Theyre labeled with a *
