LiPO Battery
That charger charges at 700mah (.7amps) and you have a 600mah battery so you need a charger that will charge as low as .6 amps (or 600mah). Charging a 600mah battery at 700mah probably won't hurt it, but that's a risk you'd have to be willing to take yourself. With a battery that small, charging it a slightly higher rate may shorten the overall life expectancy of the battery. Personally, I wouldn't have a problem with risking it.
But, if you plan on getting into bigger crawlers with bigger batteries, that charger will be pretty much worthless; it would take forever to charger bigger batteries.
Hey K_B, what charger do you suggest i get then? Well, i kinda don't mind charging the battery with that charger but i dont want to compromise the life of the battery.
Lots of guys get chargers from www.hobbyking.com but I don't have any personal experience with those chargers. My next charger will most likely be this one:
https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?src=ns&pn=HTC44151
But that may be overkill for you. And I think you can get the same thing from HobbyKing for cheaper. This is another charger with a good reputation:
https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?src=ns&pn=DTXP4235
Again, it's considerably more money than the one you linked to, but it will charge ANYTHING and the charge rate is adjustable for just about any size battery.
At the very least, I recommend getting a charger than can charge lipo (obviously) and has an adjustable charge rate.
I believe this is the popular HK charger:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=5548
Hey guys, i have a question, been bugging me for ages..i have 3 LiPo cells (one LOSI 7.4V 180mAH 2 Cell and two Yeah Racing 7.4V 600 mAH 2 Cell)..here''s the deal..i ordered them when i was overseas and im going home soon..is it safe to take those cells on the airplane?? (I have 1 NiMH cell and i know that's safe lol)..
thanks 4 the sites man, really helpful..but i meant whether there would be any reaction (lipo) or any fire risk? thnx..
