I am confused on the whole LiPo thing. The packs have to have the cells balance. Does the Onyx 235 have the balance circuitry built in? Or will I have to purchase a balance circuitry?
Back in my day we had trays that would discharge each of the 6 cells down individually. The pack had to be side by side or saddle packs, you cant do it with stick packs.
I guess this is the same type of thing.
And something else that I am confused by... Apparently LiPo packs need one lead to charge and the other to discharge. Is it because of each cell in the pack is charged individually? or are they discharged individually before charging?
Most LiPo packs come with either Deans Ultra or Traxxas plugs and then there is that other weird small plug? What do you do with that when the pack is placed in your car/truck? How do you keep it electrically Isolated?
again thanks for helping this old timer learn some new tricks
Dean
Yes the onyx does have an internal balancer, no need for anything else, it has a separate balance board that comes with it ( just to plug the balance plug into, then it plugs into the charger itself)
For ex a 2 cell lipo ( 2s) has 2 cells that need to be balanced together, they will be balanced when you plug the balance plug to the "balance board" then into the charger... I know it sounds confusing but it's really not... If u buy the charger new it will come with everything you need to charge lipos and many other battery's..
You do NOT need one lead to charge and one to discharge. ( well positive and negative of course) but not 2 separate plugs.. The 2nd plug you see on a lipo is the balance plug ( which will plug into the balance board when charging) when not charging it just dangles... I usually use a strap of Velcro to hold it in place.
The female plug that is on the battery is isolated to it can not ground out unless something is stuck into both sides...like another plug or something.
NOTE** make sure your rc has a lipo ready ESC and a lipo cutoff programmed...
Lipos DO present a fire hazard, or can easily ruin if discharged to low.
Always charge in a lipo charge bag or something of that nature incase of fire.
Since I don't want to give any misleading information, do a quick search on lipo safety!
I hope I was able to answer your questions and if u have anymore ill try to answer them the best I know!
I know the balance part may have been confusing, but it's really not, the 235 does have internal balancing, the balance board is just 1 board with several size balance plugs ( 2s uses smaller size than 3s, 4s batts have a bigger balance plug than a 3s and so on... All the balance board does is has all the balance plugs on one board to make things easy!!
Good luck and if I confused you, PM me and I can get you some pictures of how a lipo is set io when charged if you need!
Kenny
