I want to get a 1in lift kit for my wraith should I or not if so I want to get bigger tires what should I do?
What the fawk? They are too tall and top heavier than dolly parton stock why in the hell would you want to raise the center of gravity even more?
shoulda got a e-maxxxx
Lower the thing, the wraith sucks at a high center of gravity especially if you run brushless. There is one trick that I'm sure most of you know but its free. On the axle their is the shock and lower link mount that is held in by two screws on the other side, simply flip them 180 degrees. (Do the front and rear). Trust me this will work, it lowers the wraith to a better center of gravity. Their are many other ways to lower the wraith and have it with good suspension movement. Good luck.
Flip the top shock mounts too.
