Leaf spring conversion SCX10 III?
pchiumiento
Mass
Does anyone know of a conversion kit for leaf springs SCX10 III? I think I want to put them on my truck and have some fun.
P2K R/C
Yes sir.
P2K R/C
I dont think there is a actual conversion kit
There are leaf spring kits with the leafs and the brackets to hange them off the frame
The rest you have to fabricate your self but its real easy
You might need to grind a bit on the front axle to get the spring purch in the right spot but not alot of work
Ive put leafes on just about every axle except the 10.3
Og scx10+10.2
Ar60s
Ryft axles
I even did a trx4 axle with the portal delete set up
Keep an eye on jecracing.com - he makes leaf spring mounts for various Axial products, but sells out of them almost immediately.
scalemetalsupplies has perches as well ... they do state you have to mod your axle because of the top truss of the axle.
Ok thank you going to add them to my bookmarks now.
P2K R/C
