Krazed Builds - Big Bore/Dravtech Piston Tuner Sets
Our Tuner Set will give you 4 different pistons color coded for easy identification.
You can run two different pistons front and rear, find the oil that suits you and get a better control over your suspension.
Every piston has an oil groove in them on one side to alter directional flow. Whats this mean?
With the groove on the top, closer to the cap, the oil will have more direction to flow giving a little softer compression then rebound.
With the oil groove on the bottom, towards the inside, then the opposite. You will have a little softer rebound/extension for oil flow then compression.
You will get 4 pistons of each variation - thats enough to do 4 complete sets of shocks or even mix match 2 sets for two rigs.
They will fit all 10mm inner diameter shock bodies such as Traxxas Big Bores and Dravtech's.
Piston Color Chart:
White = 6 holes .052'' size
Yellow = 6 holes .047'' size
Blue = 3 holes .055'' + 3 holes .047'' size
Red = 3 holes .052'' + 3 holes .043'' size
Price: $22.00
Available: Big Bore Piston Tuner Set
International shipping from the states is crazy these days, best thing I can say is PM me here and we can work the shipping down for you.
Thanks for looking "thumbsup"
CNC Machined Delrin Pistons for Traxxas Big Bore and Similar shock bodies.
Piston Color Chart:
Price: $22.00
