It was quick build and good instructions.
Plastic quality is decent and well molded.
Transmission was the most impressive piece, just wish they offered it with a slipper. It sits maybe 5mm higher in the chassis than the SCA-1E transmission which has a similar format. Added Hudy Graphite grease and runs almost silent the axles however do not...might just need some more shimming
Battery placement did not seem optimal....like the battery to run down the middle and over the front axle like the SCA-1E or SCX10.2
The axles were some the easiest i've built, but pinion is super small but helical which is a nice touch. Whoever designed the receiver box i'm guessing is the same person who design these horrible axles. The shape is not conducive for sliding over rocks and they are square???...If it's not going to be designed for performance at least make it look good! SCA-1E axles look terrible, but probably the best design for sliding over rocks and you're able to drain any moisture or re-grease in less than a min. Go for one or the other at least.
Side plates are way too big and heavy along with the huge and ugly receiver box, they really overlooked this whole area and looks like about a 15min CAD effort. Going to swap with a Traxxas box and maybe eliminate the side plates completely.
The links are too big and too heavy.....never had a link bend on me that was half the size....plus it just looks odd. Cut the size down a mm and change both links and shafts to black.
Chassis rails do not allow for truck bodies to be slammed....unable to get a Brat body to sit as low as on the Carisma chassis. The rails have some severe angles and sits over an inch higher. Odd rail design, but the chassis has decent rigidity.
The drive shafts look like they'll hold up well and lightweight, but again very bulky and can see them being hard to keep clean.
Front drive axles are not CVDs like the cheaper SCA-1E. They'll be fine, but prefer CVDs overall as they don't grab onto mud as easily and easier to lube.
Shocks are great! just wish they skipped the all that blue anodizing. Prefer the RTR color scheme. And where are the upper shock mounting options
Was expecting a lot more from Associated and might grab another one of those incredible transmissions and move it over to the SCA-1E platform and compare the 2. So far this falls towards the end of line as far crawler platforms go for me....the overdrive transmission is probably why this is so highly rated, but the rest of just average at best and a very well designed. Should also be priced towards $179-199 to make it somewhat competitive
