Hi,
Which axles is it ?
You have been busy!!
I like the rear driveshaft!
Why did you go that route and not SDI?
What gear are you using for the OD/UD?
Good find on the brass weights!
Are those bent rod ends on the skid plate for 4mm rods?
If so, do you have a link for them?
Too bad the rod ends slots are not bent already... Making links is muck easier if the rodends are straight.
Always good to know!!
How does it work on the rocks?
Happy with it?
How about your other shafty rigs?
Did you sell them?
nice rig! and good driving.
the sway bar is a good help in the torque twist effect?
congratulations
