SMT10, Hobbywing 3600KV brushless, 2S, SSD diamond axles, standard front and full width yeti size rear.
I have a very upgraded SMT10 which is getting used as a Monster truck / basher. I recently replaced the axles and links with alu versions from SSD. Since I knew what wheels I wanted to run, and rather than rely on large offset adaptors, I went with the full width centred Yeti axle on the rear. I still have to use large offset adaptors on the front axle.
Ever since doing this I cannot get my rear right wheel to stay on. I have used copious amounts of blue locktite and have torqued the wheels nuts to such an extent that I’ve actually destroyed 2 hex hubs (see pic). It takes less than 5 mins for the wheel to come loose every time and I simply cannot for the life of me work out why it is only this one wheel I am having issues with. The rest were mounted at the same time, in the same way and have not required tightening at all.
I am using the HD version of SSD rear axle so I’m limited to using the hexes that come with them. The fit could be better between the SSD hex and the jconcepts adaptors that come with the tribute wheels. Is there anything I can do to make the fit better maybe or what other newb mistake might I have made which is consistently causing this one wheel to fall off so swiftly?
2 pictures attached. The first is a deformed adaptor, caused by the nut being tightened next to my last new one, the wheel nut I’m using and an SSD hex. The 2nd picture is the wheel nut showing how it sits and that it is what has caused the deforming of the adaptor and the SSD hex sat in place.
I also noted a comment on jconcepts website which seems like it might be very similar and I might not be the only one this is happening to?
Ideas? Help!
Ideas? Help!
